Ford Mechanic
- 7
- 38
- Edenton, NC
My last post I just gave you a easily understood explanation of some basic auto electrical theory.
Unfortunately I don't have a wiring diagram available so I can't contribute to how to test the pcb.
I belive I saw you post that you had a volt meter? I would suggest checking for voltage at that battery cut off and a volt drop test across that switch. Since your questioning it anyway.
Your truck should be able to start and run without the alternator at all.
I would really suggest grabbing a wiring diagram and follow the power flow thru the truck instead of jumping around. You'll learn alot more and spend less money. Sorry
Sent from my SM-G900V using Tapatalk
