the fun is about to begin
Patattack
Westminster, md
well i got got back from a very dusty place and while i was over there i had alot time to think about on what i was going to do to the old teeruk 1009 and this is what i was thinking. A 6.5 turbo diesel but with that ill have to redo the exhaust and convert or move the rear bat for the turbo or just go naturally aspirated, I dont know yet but i found a good 6.5 block on a surplus site with cast years from 00-05. nothing really wrong with the 6.2 exept it smokes alittle and it really under power so why not upgrade the engine. im going to rebuild the trans, mean why not its out anyways and kits are cheap for a th400. the transfer too 4hi dosent work very well i usally have to put it 4lo alot of the times. All new suspension going with a 2.5 all new leafs and sway bar, because i have no suspension its all shot the springs in the front are bent in the other direction. some padded flooring to cut down on some of the heat, its very hot in the summer, and a radio im using a boom box right now and could use a upgrade on that too. with that 6.5 i went on ssdiesel supply and getting the cooling system upgrade with the dual thermostat housing and the 130 gpm water pump. the fuel injectors are going to be marine injectors and i also found a 6.5 mech inj pump so i got that covered, going with a trans cooler to cut down thw heat on that tranny. when all is said and done for the most part i probley missed some things but the truck is going to be almost new, ill get this thing going in a month or two and the money dumping with begin!!!
:doghead:
Warthog
227
OKC, OK
Sounds like a plan.
Are you coming back it Oklahoma or staying Ft Bliss for awhile?
