- 8,229
- 20,784
- 113
- Charlotte NC
.An update on the progress on the m62. Went back in today, it's been a hot minute took some time off for Thanksgiving. Spent two weeks out in the desert, it was glorious! The old mirrors were flippity floppity and you couldn't see anything out of them so a few weeks ago I dug some out of a pile of mirrors we have and had Craig squirt some paint on them. Got those mounted. I fixed the bridge plate. And I was able to show some love to the crane operator Dash with all the data plates. Came out pretty good!
The old data plates were riveted on the dash so I had to use a chisel to cut them off. The back sides of some of them were oxidized pretty bad. Had to use a flap wheel to knock the corrosion off and then used 400 on an orbital sander and sanded both sides of the data plates. Funny after sanding you could almost read them!
After sanding and cleaning them, gave them a coat of self-etching primer and let that dry. I held the new decals up to the clean painted plates but didn't like the gray primer around the edges so I ended up spraying them silver on one side and then afixing the decals.
After the silver paint dried, sprayed a little bit of Windex on the tags and centered the decals. They came out very nice thank you very much Tim
The replacement tags I made for the control levers didn't look right without a border around them when next to the newly refreshed data tags. I just masked them off and use the same silver paint to give them a border. Next step is to mount them with screws instead of rivets. And by the way they weren't pop rivets they were the kind you got to smack to make them expand. National Guard, what can I say!View attachment 937023View attachment 937024View attachment 937025View attachment 937026View attachment 937027View attachment 937028View attachment 937029View attachment 937030View attachment 937031View attachment 937032View attachment 937033View attachment 937034
Wow Will... That looks fantastic!
Took a lot of effort on your part, but it looks really good.
Tim
