Three phase / Single phase
microjeep
472
blairsville ga.
Haven't installed a residential generator in 25+ years, but we always recommended using a line conditioning transformer for computer circuits. Maybe today's generators are better (cleaner power)? Any thoughts on this?
glcaines
2,735
Hiawassee, Georgia
I have an MEP003A genset. We haven't had any issues with computer equipment, televisions, etc. and we don't have any line conditioning equipment installed. Except for the noise of the generator, we can't tell if we are on utility power or the generator.
Scoobyshep
2,021
Florida
Line conditioning is more important when the generator head has brushes. That and back then computers used to be dirty loads with fickle power requirements. These days they are fairly forgiving.
Sent from my SM-G950U using Tapatalk
1800 Diesel
26
Santa Rosa County, FL
I recently bought an 803a for my home and I am impressed with it. I live in south FL where hurricanes are just a matter of time. So I wanted to squire one for my business, problem is an 803 is not enough for my business. So I was going to use two 804 in parallel wire for single phase.
I would recommend an MEP-005A, rewired for single phase. Then you'll have 120/240 volt and using what I've been getting out of MEP-004As after single phase conversions, you should get something between 33 & 35 KW continuous. Also, I believe the MEP-005A is a little easier to troubleshoot and repair. I can't argue about its fuel efficiency being better than an MEP-805A, but you won't spend near as much money on the original purchase cost and it won't be operated 24/7, so the fuel delta will be insignificant in the long run.
If noise is an issue, then get an MEP-005AAS version--much nicer for the HOA type neighbors..... ;)
glcaines
2,735
Hiawassee, Georgia
I still prefer the older MEP003A gensets. They are dependable. Also, they are air cooled, which means no maintenance of the cooling system. They are also relatively fuel efficient when compared to the larger gensets. They are also large enough to handle the entire load of a typical home without having to pick and choose circuits.
1800 Diesel
26
I'm with you on the MEP-003A--have operated the same unit for over 20 years and through many hurricanes down here and it's never failed. However, I'm assuming if an 803 wasn't enough output for his business, then the 003 wouldn't be either. It seems he's figured out the business load to be something more than 15KW but less than 30 KW. That's why I suggested the MEP-005A unit. He'll have to figure out what works best for his situation. We can only offer advice... :)
America
35
USA
What exactly are you using the generator for? We have to know. Then we can answer this question.
