Throttle cable and foot pedal
joeyaguirre21
el paso, texas
I have a 84 cucv. Throttle cable is not right the pedal sits half way down than where it should be and I think thats why I'm not getting the power I need. I have a couple pics of how the cable is and pedal is and a pic of where the pedal should be. Also on the IP has to nipples where you can hook up the throttle cable but it can only go on one because the other one is designed for a different cable I'm guessing I also have a pic of that. I switch the throttle cable from the first nipple where it should be to the one in the back and the peddle comes up where it should be but I can't leave it there since it doesn't allow me to put the clip so the cable won't come off.
joeyaguirre21
el paso, texas
The first pic is where the peddle is at and the second is where it should be. The third pic is how much the cable is out from the peddle and thats why the peddle is half way to the floor board. The last pic is the two nipples I was talking about on the IP. Help please
tobyS
840
IN
foot pedal
Here is a foot pedal I took off of the unit in the 2nd photo (which is hydraulic fail safe 2 circuit), just in case you want a heavy truck pedal that works really well for mounting a cable end.
cpf240
Free in Northern Idaho
Maybe your truck was one of the motor pool training vehicles for new privates? :)
Seriously, finding the proper cable has been an issue for many... the lengths of the aftermarket cables seem to vary, even though they 'fit the application'...
dougco1
708
Cooperstown NY
Take the throttle peddle and arm off and bend it in a vise. I added floor covering and then a thick rubber mat and I have the same issue. I decided as I get older I don't have to go as fast anymore so I left mine alone.
Barrman
2,225
Giddings, Texas
Is the engine by chance a HMMWV pull out? Those engines have a different throttle cable bracket on the engine. I think the bend the arm idea is your best fix for now though.
Tinstar
2,619
East of Edmond, Oklahoma
The correct GM throttle cable is almost impossible to find.
Many on here have had issues with the aftermarket cables not fitting correctly.
Either tweak it as mentioned or go to a salvage yard for a used one.
Keep looking for a NOS GM one.
Their out there. I found some and bought three a few months back.
SS member SWISS had some for sale a couple of weeks ago I think.
Not cheap but correct cable.
Kaiser67M715
26
NH
Two scenarios come to mind-have you verified full throttle operation?have the wife/girl/joe smo hold the pedal to the metal and try to rotate the throttle on the injection pump more.
Either that it's an old cable that is stretched and about to break...
