time out
tiger422
Lakeland/Florida
I am a slow typer and when trying to answer long questions I get loged off and lose my post. Is there any way to fix this problem? I dont answer alot that I could because of this.
Carl_in_NH
Wilton NH
Captain-crank is on the money; use another program for writing your post - be it your email program, or almost any other simple text editor - then copy and paste into the posting window.
Here's another tip; once you copy and paste it into the window to post in the browser, highlight the entire message and press the button at the upper-left hand corner of the box where you're entering your post (the tool-tip 'Remove Text Formatting' will appear if you hover over it). This will remove formatting that can cause strange and unreadable messages with oddball color combinations. Many people don't do this, and it makes their messages hard to read.
Warthog
248
OKC, OK
You can also use the "Remember Me" check box when you login. It will keep you logged in until you hit the logout button.
armytruck63
10
Morro Bay, CA
Warthog is correct. I just found this out the other day when I was using a shared computer at work and did not check the "Remember Me" button.
