- 2,102
- 28
- 38
- Delta Junction, Alaska
![DSCN0013.jpg DSCN0013.jpg](https://www.steelsoldiers.com/data/attachments/367/367337-d2b0aacb3bd09181b5ae1e442c317fe4.jpg)
Are you one of those ice road truckers? We get this program on discovery channel here in ItalyView attachment 538100The hook, about 42" long, made from 3/8 round stock, is standard equipment ( also a scoop shovel), on my vehicles. Its used to reach out for something, like pulling the inside chain rail between the tires, to get it hooked. Chaining up, should be practiced some. The best advise is "when in doubt, stop at the bottom and chain there". Spinning out is not the issue, its sliding off backwards. Your side rails need to be just long enough, to get them hooked, but not too long. I would carefully place them over the top of the tire, slightly off center, to allow me to pull the center rail between the duals & get it hooked. Hook is the key word. You don't want a cam latch there, but a hook, also on the inside rail. Then when you latch the outside, you take up the necessary slack. We don't run tighteners - they are not necessary, and take up too much time. When going to the Beach (Prudhoe Bay, 518 miles), we had real hills - 11 & 12%. Federal Highway Standards are max of 6%, and that is rare. All the Hills had names , like Finger Mtn., Ice Cut, Roller Coaster, Beaver Slide, and so on. With chaining conditions, you would chain for each hill, then take them off to run the flats, so you got good at it.
There the same thing we use on our busses when we have to chain them up. They work good. Only last a couple of years though. Get spares.Why not just cut tails off?
There gonna be the same if all tires are the same like
they are supposed to be on an all wheel drive truck yes?
I will say it again, look REAL HARD at the rubber chain tighteners
Uncle Sam's is selling. They are NOT bungies, they are a rubber
circle just like a GIANT O Ring w/ clips. The rubber is like 1/2" THICK!
Thanks Artisan for the link and tip to Uncle Sam's for the tighteners! However, I'm a bit confused by their description:Why not just cut tails off?
