Tire comparison picture
cranetruck
94
Meadows of Dan, Virginia
You may not have known it, but there was a larger size NDCC tire made, the 16R20 or 16-20 NDCC used on the XM757/M656/XM791 8x8 trucks. It's a low profile radial on a 12 inch wide rim here shown with the 900-20 NDCC. Designed for tubeless operation and only 30psi on the highway.
They measure about 44 inches in dia and are 15 wide.
To replace them I'll have to find 395/85R20 or similar.
maddawg308
802
Appomattox, VA
Now we gotta get AMGeneral to show a pic of the 14.00x24s that he has for his M123 next to a set of 11.00x20s, and a set of 9.00x16s. :)
M1075
Oklahoma City
Here is a comparison of a few different sizes. Sorry but the 900x20 didn't make the pic.
L to R
Titan 1100x20 NDCC
Michelin XML 395/85R20
Michelin XL 15.5/80R20
Michelin XL 14.00R20
Michelin XZL 16.00R20
M1075
Oklahoma City
Yeah, it is a handy reference pic but next time I will include the 900x20 NDCC, Michelin XL 1100R20, Michelin XL 14.5R20 and get all the tires on level ground. I have all of these size tires currently in operation.
cranetruck
94
rdixiemiller said:
Bjorn, the 14.50R20's I picked up are right at 44" tall and 14" -15" wide. They might be what you need. The 395's would also work, I think they are 45-46" tall.
I think you are correct Robert, the 14.50r20 uses a wider rim, 11 to 12 inches which is perfect for the xm757. the 395/85r20 is spec'ed for a 10 inch rim. According to the michelin data sheet, they are both rated at 55-56 mph max.
How much did you fork out for those and who carries them?
Thanks,
BTW, the original 16r20 NDCC tires are shown in my current avatar.
houdel
11
Chase, MI
Yes, it would be nice to see where the 9:00-20 stacks up. The OD and width the various tires would help too, as a standard Deuce is pretty much limited to 46" diameter tires. I'd like to get the max width in a 46" diameter tire to run super singles.
rdixiemiller
Olive Branch Mississipi
Thanks,
I went after 6 for $300, ended up with 9 for $350. Then got 6 of the 10" flaps for $10 each. Got them from a guy in Phenix City Al. I got all he had. Can't remember his E-Bay handle, but he always gives his location as 100 miles S of Atlanta. I have 2 75% tires, the rest are 40-45%. Fine for my use.
M1075
Oklahoma City
As far as I know, you really only have 2 options in a 46" tire. Either a Michelin XML 395/85R20 or Michelin Pilote G-20 XL 15.5/80R20. There are effectively the same width(15.5") with different tread patterns and load ranges (ply).
AMGeneral
116
Connelly Springs, NC
Finally got my camera working again,so here's some comparison photos of a few more.
Left to right in each pic,
1800R33 GOER tire
1400 X 24 10 ton tire
1100 X 20 tire(no rim)
900 X 20 Deuce tire
700 X 16 1/4 ton tire
Sorry,didn't have any 900 X 16s laying around,the small stick standing next to the GOER tire is a 12 lb sledgehammer with a 38 in long handle(for comparison).
