hummer4x4guy
- 3
- 18
- Lansing, Mi
Guys,
I am getting a 35.5V reading between the two batteries with the truck running and I cant adjust down the regulator any further. Tho it does properly adjust the voltage up and down as it is turned. Is this issue simply solved with a new regulator? With a new washer pump on the way I dont want to burn up a new one. Funny tho that none of the lights act as if they are getting too much juice and running too bright or the wipers running faster than normal.
Thanks.
Thanks.
