Too high voltage. suggestions?
hummer4x4guy
Lansing, Mi
Guys,
I am getting a 35.5V reading between the two batteries with the truck running and I cant adjust down the regulator any further. Tho it does properly adjust the voltage up and down as it is turned. Is this issue simply solved with a new regulator? With a new washer pump on the way I dont want to burn up a new one. Funny tho that none of the lights act as if they are getting too much juice and running too bright or the wipers running faster than normal.
Thanks.
hummer4x4guy
Lansing, Mi
A question: Isn't the voltage regulator on our alt. the same as on most other newer M series trucks? Seems like there aren't a lot of places or ppl who sell them.
Retiredwarhorses
4,482
Brentwood, Calif
What generator do you have?
60amp is adj, 200 amp is not...if a 60amp model, if it can't be adjusted to within specs, it needs a new regulator.
of a 200amp, just replace the voltage reg on top of the Gen.
