too many miles??
galeo7171
14
Cumming, Ga
When I picked up my m1009 from Ft. Jackson, I was told it had 23,000 miles on it. After some research (from a member here, thanks again), I have discoved it has 123,000 miles on it. It belonged to USPFO transportation at Fort Jackson. I have no idea what USPFO means...anyways, is 123k miles a lot for these trucks? It seems to have been taken care of. The only rust is mostly surface rust and the only leaks I have is the rear output shaft of the tcase and my injection pump is leaking when I shut the truck off.
SCSG-G4
PSVB 3003
5,403
3,508
Lexington, South Carolina
USPFO - United States Purchasing and Finance Office. Probably used to run around town, not much highway miles. if it has good compression and you do an engine oil analysis (from NAPA, kit is about $15) that comes back good, you should be fine IMHO.
mangus580
284
Western NY
123k is nothing. Just barely broken in ;-)
Its common that the miles are reported wrong, since they dont have 6 digits on the odometer.
dependable
188
Tisbury, Massachusetts
On one level that is too bad, But some of the problems you would have with a truck that has sat too long might be just as bad, but different. If the crew that used this truck maintained it, you may have a good rig,
CARNAC
The Envelope Please.
724
College Station, TX
USPFO is actually United States Property and Fiscal Office. It is the people who provide property and financial support for each state National Guard.
desertfoto
Terlingua, TX
My 85 Suburban is an ex US Forest Service vehicle. It had 70,000 hard miles on it when I got it in '94. Since then, I have put 245,000 hard miles on it and just replaced the engine a month ago at 316K. Chevy trucks last a long time if you do regular maintenance.
galeo7171
14
Cumming, Ga
Thanks for the replies....I'm guessing it was taken care of from the looks of things. I should just stop worrying and just drive the crap out of it
maritimer
Yarmouth, NS
i have 70k miles on my odometwer and io know that there should be a 1 in front of the 70 and my baby runs like a top besides the regular to be expected stuff cropping up due to its age , if it is maintained properly you can expect 500k or more from these trucks
