- 8,292
- 686
- 113
- Corpus Christi, TX
Just get a common number 1 tool set and you'll be ok.
Go to your local truck stop and buy a gladhand, install a reducer and female quick-disconnect on it. Install male and a quick-disconnect female on a 25' air hose, roll up and store in tool box.Only thing I want to change is taking the glad hands off and running a actually line and quick couple fitting to the rear of the truck and off both sides at the cab.
Yep already planned on itYeah that's what I read in all the searching I've done, that the 3/4" works great on the deuce air. I plan on adding a 10 gallon tank in the bed tool box with a valve so it won't be filling constantly off the truck till I need it. Only thing I want to change is taking the glad hands off and running a actually line and quick couple fitting to the rear of the truck and off both sides at the cab.
So you been working on tractor trailers since you were 12 years old ?( your profile shows you just turned 28 ).I'd rather not.... I've been dealing with and working on tractor trailers for the last 15 yrs and those glad handles break and leak at the most unopertune times. I'd rather just have a quick couple on the back of the truck. I under stand what you guys are saying it's easy, but I'd rather not lol.
