Tool Sizes- Sockets and Wrenches
862
Reading Pa
Ok so I searched all day today an only found a handful of "opinions" on socket sizes and wrenches for the deuce. Some of the threads that had pictures at one time do not work now or the links are no good at all for the depot master mechinc sets.
im getting a tool set together to keep in my deuce at all times for wheelin and to help buddies out with smaller civilian trucks.
is there any need for 1 1/4" + size wrenches on the deuce? I did pick up a 3/4" jumbo set from harbor frieght mostly for changing tires and to have a decent size socket set, but is there a need for the bigger sockets? What about wrenches? I'm going to get wrenches from tractor supply (cause I'm kinda OCD about matching things) and I can get wrenches from 1/4" all the way up to 2 3/4" I believe.
now I will be getting a double set of wrenches from 1/4" to 1 1/4" and obviously the bigger ones I only need one with a companion 18" adjustable.
What at is your take in this? I will be bobbing my deuce so all the stock suspension in the rear will be getting scrapped.
thanks Dan
hndrsonj
Senior Chief/Moderator
359
Cheyenne, WY
I have a 3/8 and 3/4 inch socket sets and wrenches up to 1" and a big crescent wrench.
doghead
4 Star General /Moderator
1,193
Do you only want facts(no opinions posted)?
Next time, please continue an existing thread for something like this.
The fact is, The BII tools are what you need. Anything else is a matter of opinion.
862
Reading Pa
Some of the exist threads are years old and I have tried this before and no one replied or reply as do you know how old this thread? Also some of those threads don't exist anymore. That's why I'm posting a end thread.
Hndrsonjr does only having up to 1" cover most of the tools?
sandcobra164
323
Leesburg, GA
A good 1/4", 1/2", and 3/4" socket set along with accompanying wrenches, screwdriver's, pliers, and a fitall wrench will get you far. You also need a bud nut socket for the lugs and thimbles and a 3" eight sided socket for removing axle nuts. I usually keep all of that plus some sort of bench stock in the truck such as a few wheel cylinders, DOT 5 brake fluid, some grease and some axle seals whenever I travel. Overkill for sure but I could do a wheel cylinder or axle seal on the side of the road and just about anything else if needed. It's a new year so my truck is now 43 years old. The only thing I don't take on the road is my torque wrenches. They don't like the constant vibration and tossing around from what I've been told by the guy that calibrates them.
862
Reading Pa
Yeah for sure on the 8pt axle nut socket, and I have tire tools I did that stuff for 13 yrs so I have hammers irons and sockets. Also plan on keeping fluids and extra filters too. I was just curious on socket and wrench sizes.
gimpyrobb
dumpsterlandingfromorbit!
27,791
788
Cincy Ohio
Many years ago, I purchased a mechanics tool set from Home Depot for $180. It has been the perfect deuce tool set. The wrenches only go up to 5/8(my opinion is they should go up to inch and an eighth), but the sockets go up to inch and an eighth. You will need larger sockets for the lug nuts and hub nuts, but not much else. In the end, I bought another wrench set that goes up to 1" and life with the husky mechanics set along with the wrenches up to 1" have done real well for me.
Lt. Dan, PM if you want some links to a similar set on an auction site I am not allowed to link to.
319
Lieutenant
3,347
58
Michigan
I have the axle nut sockets ( new ) available. Check the classifieds or click on the link below.
862
Reading Pa
Thank you gimpy that is exactly what I was looking for, well not the husky tool kit but it answered my question! I have a decent set of tools at home and a second set that is even bigger at work. But I wasn't sure about sizes of bolts and nuts on the deuce.
My my dece is gonna be the ultimate (or try to be) recovery/offroad truck. I'd like to almost do any repair besides a engine swap or similar out of the truck. I plan on having a decent size tool set in the truck along with co2 tank or a air compressor ran off the pto, torches, welder, stuff like that. Basically want to be able to be self sustainable for almost all repairs on the truck or any other truck or 4x4 to make it home.
swbradley1
Modertator
1,945
Dayton, OH
I know a thing about Gimpy's tool set and his girlfriend. I'm not sure which he would miss more if they were gone. :)
It is a heck of a tool set.
gimpyrobb
27,791
788
Cincy Ohio
I get the girls because I'm good with my tool!
LT. D, I doubt you would need over 15/16 for most stuff on a deuce. Even at that most maint. stuff is 5/16-9/16.
You'd also be surprised at how much you can strip from a deuce when you only have a Gerber multi-tool with you!
dmetalmiki
2,036
London England
I (also) carry air impact (type) sockets up to 1 5/16 in 3 drive types up to 1". Full wrench set. 3/8 up 1 5/16. fuel filters oil filters. brake fluid. 1" (and 1/2") drive air impact guns. (run from the rear glad hand).
73m819
329
gainesville, ga.
You can not over kill on what tools you carry, DEFINE the MISSON for the truck, then build the truck for that mission, and REMBEMBER, it is better TO HAVE and NOT NEED then TO NEED and NOT HAVE.
862
Reading Pa
How's the 1" gun work on the deuce air supply? Like I said I ran 24/7 road service doing tractor trailer tires and heavy equipment for years and we had air compressors that ran off hydraulic pumps and they worked excellent. I was only going to get a 3/4" air gun
welldigger
17
Benton LA
The deuce air supply would struggle with a 1" impact. I think the system is only capable of approximately 7 cfm. The air tanks are also pretty small. Only a few gallons each. You may could run a 3/4" impact in very short bursts with lots of waiting for the system to recharge.
Tow4
674
Orlando, FL
3/4" impact works fine on a Deuces air. When I changed tires, I pulled hand throttle out to about 1500 RPM while running the impact and I had plenty of air. Use 3/8" air hose from the emergency glad hand on the rear.
862
Reading Pa
Yeah that's what I read in all the searching I've done, that the 3/4" works great on the deuce air. I plan on adding a 10 gallon tank in the bed tool box with a valve so it won't be filling constantly off the truck till I need it. Only thing I want to change is taking the glad hands off and running a actually line and quick couple fitting to the rear of the truck and off both sides at the cab.
shenkmen
12
Lancaster, PA
Instead of removing the glad hands you might want to adapt them instead.
Iski
CT
I run the 1 inch impact from the glad hand for lug nuts and it works well.
