torque rod bushings
HN6
402
alaska
Along with the weld on the edges of your plate, a 3/4 inch hole drilled in the center and plug welding that - your metal "keepers" should stay in place. Need to have a 5 gallon bucket of water to cool the metal before the rubber is smoked.
Thanks, I only plug welded the center with about 5/8' hole. When I replace the bushings and weld new keepers I will make the plates better and weld some outside edge as well. Hopefully to last a lifetime.
I did not want to quench them in the water as to change the molecular structure and make more brittle but maybe on this application it is ok. typically it is a huge no no welding steel on anything structural and cooling rapidly.
20,642
Normally no, quenching isn't a good thing. Only reason I suggested that was that our welder who always did that job for us did it. Once those plates were welded - they "stayed stuck". The truck would get new torque rods at the 7 year rebuild if the rubber had separated. Going from memory the rubber didn't smoke with the 5 gallon water quench.
That particular welder had worked on the Alaska pipeline and later for the railroad.
He seemed to be more experienced than some of the others.
HN6
402
alaska
Actual real world experience
Perfect! Thanks for the feedback. Greatly appreciated.
Jeepsinker
470
Dry Creek, Louisiana
I've read/watched quite a few people's techniques on getting the rod joints out. So far, I havent seen anyone use a traditional style fork separator. Do they just get bent all to hell and not work? If turning the nut against some janky stacks of plates works, I don't see why not.
Kind of wondering if I should go through the trouble of machining myself a big screw-style separator. I've got some pretty big diameter steel bar stock that would work.
I'm buying the ones with the integrated keepers and will be doing some of them soon enough.
Can't believe you called my carefully selected plate stacks " janky" 🤣🤣
7bdiver
171
33
idaho panhandle
I bought a big chisel at harbor freight and milled the center out. Havent tested it yet though. Its just been too dang cold and shitty out to bother. None of my bushings are at risk yet anyway. We'll see how it goes.
I made the same thing out of a big long sds max chisels too, in case I want to try it out with the mini jackhammer.
rustystud
3,371
Woodinville, Washington
Looking good on that pickle fork, but I would make the taper more. Say a 16 to 20 degree angle. Something that will get under/behind the rod. Last time I had to replace the torque rods, I used steel shims that where about 1.5" wide and 6 inches long and used my 4 Ibs mini maul to hammer them. I like your idea better.
