joesco
- 1
- 18
- Hampstead, NH
Has anyone towed an M931 with a M931A1? Sounds like a good tow bar and airline hook-ups should suffice??? Thanks!
And safety chains.Has anyone towed an M931 with a M931A1? Sounds like a good tow bar and airline hook-ups should suffice??? Thanks!
Dave This is Rick Koetter, I purchased a few M936 wreckers and need to tow and M923 cargo truck, I need to know what all tow bars and rigging I will need and where I might find it, can you help? If so please call me at 502-643-2909 ThanksIf your route brings you through (or near) Columbus IN, I have a medium, along with gladhand air lines if you don't have them.
We can likely work out some sort of reasonable trade......
PM me when your timing firms up and we can talk details.
Dave
... and tow board / lightsAnd safety chains.
Came here to suggest this.Another option (if you can find one) is one of those 5th wheel lifts.
I thought this question deserved a separate answer. I think that if you were to put about 8000 lbs in the rear of your 925 it will pull it up that hill all by itself. But if you don't want to try it alone by all means hook up and go with both but I would hook up the air lines from the front truck to the second so that the front driver is in total control of the whole thing and would still recommend the weight in the beds of the trucks.NEED OPINIONS AND RECOMMENDATIONS on similar topic (Not attempting to hijack thread) I pulled an XM1073 trailer (7.5 ton) from WVa with a 12,000 crawler on board with my first 923A2 to Denver, Colorado.
NOW, I want to hook my 925A2 to the front of my 923A2 (with a mill spec bar) so I can pull the XM1073 and crawler up a mountain road. The pull would be about 8 miles with a few short grades in the 15-25% range. The 'road' is not a 'jeep trail' but it is not even up to county secondary standards. I don't want to 'walk' the dozer 8 miles.
IDEAS?
THINKING ON SUBJECT?
RISKS?
POTENTIAL DAMAGE TO either 6x6? (Most important factor)
Convoy of trucks is much safer, b/c all LEO assume it's military. Don't think it's the same with one truck. I think attire also makes a difference, wear military gear and you are more likely to get waived through.Tonight, on my way home from the Black Hills of SD, coming down hiway 81 from Neb. into Kansas I passed a convoy of about 4-5 pairs, one truck pulling a second truck on a towbar, of 5tons (M813's) out Lincoln, Ne. Not one had a plate and I bet they never stopped at the weigh stations and bet they never even got a second look from the cops.
