- 5,580
- 351
- 83
- DESOTO, KANSAS
Standard practice is to always use a safety chain when using a tow bar! Also if there is a way to remotely apply the brakes in the towed truck you should do that too.Question is could a competent welder reinforce the Ibis bar to avoid the failures. If so....... what areas need reinforcement? Maybe add a safety chain so if it came apart all it could do is run into your own Arse?
