jesusgatos
- 28
- 38
- on the road - in CA right now
I just posted this reply in the other thread:We have talked about it a lot here in wyo and were woried that as the axles articulate the distance center to center on the axles changes. This might cause tracks to become too tight or too loose. Any thoughts?
...it would be pretty easy to measure the changes in the distance between the axles throughout the whole range of suspension travel. I think the important measurements to take would be, 1) at ride height, 2) one axle fully-drooped & the other axle at full compression, 3) both axles drooped (hanging). The links that locate the axles are pretty flat, and they're mounted fairly close together at the chassis-end, so I'm guessing that the distance between the axles won't change enough to make running tracks between the two rear axles a problem. Then again, I don't know anything about tracked vehicles....
