Trailer Decking
frodobaggins
Ruston, La
I don't know which ones you are referring to, but we don't discuss upcoming auctions on the forum at all.
If you need some help, I'd be glad to help in PM.
2,419
As Frodo said...all the smaller trailers...are metal
Most of the flatbed/lowboy trailers have wooden decks or at least a combination.
To give a specific answer I think you would have to specify a trailer model?
hndrsonj
Senior Chief/Moderator
363
Cheyenne, WY
No PB just get a really rusty small one (101 or 105) and put in a wood floor.:roll:
2,419
Well...that's a possibility...but I think 4X4 kinda wanted something sorta original. Don't think there is a trailer with any sort of wooded deck under say 5ton? Could be wrong.
hndrsonj
363
Cheyenne, WY
Wasn't there a 4 wheel trailer (possibly a bolster) that had wood decking. Thinking Wrecker had one, if I remember right it had a support in each corner.
papercu
31
Baxley, Ga.
but really want wood as I live by the coast
I guess by that is he is wanting wood because of the rust but would it really make a difference? After all the rest of it is going to be metal. Wayne
wreckerman893
Possum Connoisseur
15,626
2,039
Not me....all the military trailers I have now or have owned were metal.
Most of the big trailers the Army had (that I pulled) had a wood or wood/metal combination deck. This included the road trailers that were pullled by transportation units.
I have seen some big lowboys on GL that had all metal decks but some of them looked like modifications. Since military trailers spend a lot of time sittiing out in the open they always had problems keeping the decks from rotting. In their infinite wisdom the military decided that painting the decks was not authorized.:roll:
I know that quality decking lumber will knock a hole in your pocketbook.
papercu
31
Baxley, Ga.
Actually I've had more than one carpenter tell me outdoor items will last longer if not painted, by not painting it allows the wood to dry out when it get wet. And if the wood is not complete dry and you do paint, that just traps the moisture inside and it rots from the inside out.
We still have a few old unpainted building built by my Grandfather that are still standing so I tend to believe them. Wayne
4x4 Forever
Emerald Shellback
Many thanks for the kickbacks. I was looking for a wood deck as it ususally lasts longer. I had a friend that got a trailer from a state surplus sale and it lasted only 3 years before rusting through and had to R/R it with wood. I did not know if all of the trailers were all metal.
As far as sealing a wood trailer, you can use Thompsons water seal on it every 4 years, only treat the topside and let the sides and bottom breath. Has lasted me 20+ years on 1 trailer I have. BTW, keep all leaves and such off the wood and it will last longer..
Again, Thanks!
frodobaggins
Ruston, La
Again, Thanks!
Take care of a metal deck, and it will last a lifetime. One of my trailers is a 1952. It looks like it's 5 years old.
Stalwart
33
Redmond, WA
I like metal, you can roll on another coat of paint at any time. Even with diamond plate, it is slippery when wet, but I don't use it much in bad weather, most MV shows are in the summer.
