Transfer Case / Transmission Fluid Level Issue
ODdave
lansing michigan
what wrench did you use to get the plugs out?
205= tag on the front, blue ink
208= tag on rear, red ink
you can also tell what it is by the shifter. if there is a square plastic bezel and no writing on the nob its a 208
Just a rubber boot and shift pattern on the nob, its a 205
ODdave
lansing michigan
205, you are correct on you drain and fill. correct fluid..... not so much
You say this is in a 1009 (blazer) ?
The tag i am refering to is a round one with a single screw in the middle. tells the model & ratio. That silver tag is meaningless to you for basic identification
1,175
Wow, 205! There's your problem, you have the wrong T case!:razz:
wired1000
Chicago, IL
I used an adjustable wrench. I did not have a crescent in the correct size for those square bolts. from what I recall it was approximately 13-14mm
ODdave
lansing michigan
lol, i have a deuce bed full of them. Just had to give you some shi*. In the civi world the 205 takes 80-90 gear lube. I have seen mill ones with atf. the gear lube climbs the gears better as the 205 dose not have a pump in it.
PS, it is better. Keep it !
