Transmission noise
ARMYMAN30YearsPlus
Parkville, MD
M35TOm is that .69 in now? I know you posted this in a link but I am curious about the .69 performance and am considering that mod myself when I retire so if the gears are available where do you get them? I have a mill but I am not set up to do helical gears with it.
m-35tom
226
eldersburg maryland
alphadeltaromeo said:
m-35tom said:
but the point is that when everything is right, no noise.
I'd agree...but there will be some noise, but nothing like what is being described by roger.
there is noise, if that is what you would call it, in 1st and rev since they are cog gears. but there is normally NO noise in any other gear. if there is, there is some problem. many of these transmissions are plagued by water and resulting rust because of the shift boot location and a leaking top or windshields. mark to further explain, the gear you thought was worn is in fact as close to new looking as i have ever seen. the marks are what is left from cutting the gear with a gear hob.
m-35tom
226
eldersburg maryland
david, the cnc machine ($500k machine, $40k parts) needed to cut my gears is waiting parts, should be very soon.............
armadillofz1
Tucson, Arizona.
digging around in the search feature i found this old post. seems to be about the same problem i'm having. fifth gear at higher rpms whines like ****. seems to be louder the warmer/longer i drive it. it fades at neutral throttle, but very pronounced at on and off throttle. fluid level is right and seems to have very clean/new fluid in it. it also seems to shift a little harder when warm. i'll pull the top off this weekend and take a look.
*edit* Hard to belive the word hel.l. is blocked. gee willakers! oh fiddlesticks!!
tm america
25
merrillville in
i agree with you tom the 3053 has helicut gears which are not noisy.unless something is wrong . like bearing. or anything that has to do with alinement.anything that makes it run off center will make it noisy.bad pilot bearings ,missing dowel pins,loose trans to bell housing bolts,or loose bell to engine bolts can cause it to be noisy. my bell to trans bolts were loose making my trans hard to shift and noisy. i tightened them up and now its good as new.those bolts should be safety wired as hard as they are to get to with the trans in the truck:cry:.even just a couple thousands off center will make the trans loud and hard to shift.
bond024
Centennial, Co
yea, I had just bought a deuce a few weeks ago. When I was driving it I was having a loud whine in fifth gear too. I drove around town for about 2 hours and then at the end of driving, I headed on the highway and a few minutes on the highway at 50mph the tranny started to smell and then i had lost some power and got real hard to shift. I got off the highway and pulled over in a parking lot to check. Went back to my house just fine. Let the truck sit for a few hours and went to start the truck back up and heard a sound like the monkey crawled in the tranny. Now when I put it in Neutral the truck still wants to pull forward and make a noise i have never heard before. I have a new tranny on the way and hope to get to it this weekend.
JTugwell
Pensacola, FL
mine does the same. never misses a beat, but loud as ****. are these something that a transmission shop can rebuild? id hate to buy a new one, and have the same problem now that I know that there is one.
1,144
So did you do a post-mortem inspection on your transmission?
tsstout
Manhattan, KS
My deuce has developed this exact problem... What have all of you done about it??? What can be done??? Help please.... I'd hate to see her turn into a wheeled storage shed....
I contacted the website m35 posted... anyone else gone that direction???
Thanks.. Terry
oldshep
Clever,MO
Mine has made noise in fifth for a while now. But it never gets any worse. When I got the truck i found a couple chunks of metal in the gear oil and it looked like i had gone panning for gold. But it still runs fine. :beer:
volver
Moline, IL.
Have a whining noise 40mph and above. Pulled trans. Replaced the 3 ball bearings with a higer load rating and the pilot bearing. Spent 10 hours and 200 dollars on this job. It still whines. Help. lol
tm america
25
merrillville in
i would say the most common thing to make a transmission make noise next to the obivious things you would have seen while you had it apart like pitted teeth or bad bearings is a miss aligned bell housing..If the bell housing is not centered on the engine or the trans is not pulled all the way up to the engine it will force the input shaft to sit on an angle thus causing the input gear and counter shaft to be misaligned and will make noise just as a diff would if the gear is not properly set up.
First thing i would do is pull the trans back out and mount a dial indicator to the flywheel and spin the engine around to verify the bell housing id true to the crankshaft..Second check end play on the trans to make sure everything is installed correctly and nothing is moving around...If everything looks good from there i would put some marking compound on the gears and load it as best you can and look at your contact patterns?..>you should have a max of .003 run out in the bellhousing
tm america
25
merrillville in
Also are you sure it is the trans not the transfer case making the noise?Does it change from gear to gear?does it go away in 4th gear?There is alot of diagonstics that must be done before condeming the trans as the problem?If it just gets worse with road speed and doesnt change with gear changes it is most likely not the trans.. In fourth gear the input and output shafts are coupled and this eliminates most of the gears as being the issue?Does it change when the steering is swayed from side to side when it is making the noise ?if it does it is most likely a wheel bearing if it just gets worse with road speed and there is no change from gear to gear just effected by speed it is most likely a bad bearing in the transfer case?If you wanna pm me i will give you my number and i will talk you thru finding the problem
Tow4
670
Orlando, FL
Everything in the drive train whines. The axles are going to be a major source of noise too. If you put a muffler on it, you can hear the noise better.
There's a reason for the "hearing protection required" sticker on the dash.
volver
Moline, IL.
I agree. You would not be able to hear this whine over the passenger operating the machine gun. LOL. It is louder than normal operating whine i believe.
Parking break is missing a pin for the U shaped separating spring. Opps. Should have check there first. Going to piece some hardware together to make a pin.
volver
Moline, IL.
5/16th bolt with 1/2in bushing threaded into old brake shoe pin hole. Used .015 feeler gauge to set adjustment of shoes. The whine got better. W00T! No longer sounds like a Wookie. But same high pitched whine still exists. Looking like it might be transfer case. Going to pull drive shafts and spin transfer case while not moving.
