sandcobra164
- 323
- 83
- Leesburg, GA
Just make sure you spin the input to the transfer around 2,500 rpm or so to replicate the speed it spins going about 45 mph down the road. You can do that with the trans shifted into 5th and tach sitting on about 2,100 rpm. That's when mine starts whining. You'll probably be disappointed, mine only whines under a load and removing the driveshafts will remove the load so it'll probably be quiet for your test. Mine got somewhat quieter when I drained the old oil and put Non Detergent 40W oil in it but still whines under a load and is quiet when coasting.
