crazywelder72
- 2
- 0
- Winchester Ma
i am having trouble downshifting and i dont know ht. i have to coast don to about 15 mph before i can drop from 4th to 3rd or it will grind.
any ideas?
any ideas?
The idea is, if you are downshifting; Your trans will be going much faster once you downshift it because you are still moving at speed, but your engine speed will be the same as if was still in 4th. If you give her a little throttle before you shift into 3rd then you are making an easier transition on your engine and therefore an easier shiftI will give it a try. I am sure its easy once perfected but now it goes against everything i know. I am trying to stop or slow down so raising rpm's seems counter intuitive.
I tried double clutching, only helped a tad sometimes. I have not tried to raise the rpms, I can give that a try.
How would i differentiate between a bad shift key or a bad syncro?
Anyone have any pics of either part?
Sorry, I never really advanced past that middle school maturity level. Maybe one day there will be hope for me.I saw the title and thought, oh god someone is going to throw a zingger about this one![]()
