jw4x4
- 6
- 38
- Dayton, Ohio
As you well know, that type of thing was really bothering me the whole evening. I am not trying to be a d#@$, I just always think worst case scenario and have a huge concern of safety.
Details, blueprints, diagrams, impressive, video, wowHere is a picture of my sled that I built. We play with it at our annual antique tractor club event in November. It will stop a 100 HP tractor and any regular 4 wheel drive pickup. It does very little with a duece or 5 ton other than just be a nusience to it. MDMORGAN pulled it with his Dodge 4x4 and it stopped it the second pull because we forgot to put the weight in gear on his first pull.
There is the Liberty Truck and Tractor Pull in White Plains, Ga. Just a short drive from Durhamtown. If folks are serious about it maybe they could be contacted and set something up.Not to be a negative nancy, but I can see a "home made" competition going south pretty quick. Either something will get broken, someone get hurt, or property damaged. Probably just not a good place for it there.
It would be interesting though if a sled could be brought in and some track setup for it near the campground to do it right.
When we pulled... the sled was at 52,000 lbs and he had the box at the top by 120', (usually meant for Pro Modified tractors), and had the pan drop at 180'...That's awesome. How much did the sled weight or what was the sled weight up to when he stopped? Most of the pulls by me don't allow anything over 10k lbs.
Yea I had 3 girls riding with me ... one was recording from in the cab on both runs. I'll see if I can get in touch with her to see if she posts them on youtube. I'll post a link is I can.Right before the run, a lovely young lady asked to ride. Gimpy was supposed to be recording inside the cab, but I have not seen any evidence.
I did this on purpose on both runs, just to see what the truck would do under a heavy load in high, then low range... It shifted pretty smooth in high and low range. First pull in high it shifted to 2nd gear, but never down shifted back to 1st under high load... just pooped out on the converter.That was the first time I have ever hooked anything to a pulling sled. I made a rookie mistake. I approached the sled and backed with the transfer case in high range. Got hooked, and put the case in low. When I shifted the transmission into gear, dummy me put it in 5th and let it shift on its own. What I should have done was use 1st and only let it shift into 2nd, until I felt the sled start tugging me down, then manually shift back to 1st and let it eat. I am proud of this first attempt and eagerly looking forward to the next time.
JW if your interested, I'll let you know if there are any close pulls coming up the rest of the season. We can hang out in the pits with the dad and his tripple 440 Chrysler Modified tractor.Buddy, I was certainly thinking of you. These hopped up diesel trucks are insane. They even had a gasser class. One truck had a Steve Schmidt mountain motor. It didn't roll the coal, but a screaming mountain motor is sweet music to my ears. I was pretty fired up the whole evening. Had a great time. Big craving for more now.
It stopped both of us in 2nd low... I think it would have needed 1st low to keep the rpms wound up to hope to keep it going. It will be interesting to see what the addition of the turbo will do.Food for thought, when doing really heavy loads like that manually shift the auto and keep it in 2nd. Dropping it in first will after being in second would just wind out to much, second is just right for the girls.
Now of you started in first low and kept the rpms at the max torque level I agree, you would have taken the sled home with you.
Glad you had fun
You are the wiser one. To not risk damage. I felt a little better knowing there were two tow bars at the ready.I think you both would still be pulling in first low but that's just me. I was the chicken who didn't want to break his truck.![]()
