llong66
- 2
- 0
- kokomo, In
I have been working over the winter getting the turbo installed on my newly rebuilt 6.5l. I had been running it N/A as I ran out of time with the cold and funds last fall to complete the turbo install. This last week, i got it finished and one of the first things I did after checking for leaks etc was see how hard the turbo input was sucking air....its ALOT! When you increasse RPMs and let off you can hear the turbo, but I was getting nothing on my boost gauge, I tried another gauge, same results, nothing. After piddling around, I removed the upper intake so I could get a good feel at the turbo output....nothing, no air at all that would give me boost. I know enough must be getting through to run the motor and it runs good, not driven it, just working in the drive way. My question is, what could cause this and what should I do? The turbo is a '96 GM5, Borg Warner. From what I see of the rebuild kits there is nothing that would fix this, the air going in must be going someplace...
This is my first turbo, but I don't know of any adjustments, the intake fan is spinning so the exhaust fan must be. Its spinning fast enough I can hear it.
ANY ideas or suggestions would be very helpful.
Thanks for your time!
Greg
Greg
