rlwm211
- 19
- 38
- Guilford, NY
Next is the Deuce Bosch AMBAC mythical Injector pump......I hope
I'm unsure about the exact differences. This rebuild kit will not work with the 3LM type turbos, which is the "D" type. Hmm, I may need to do a thread on that in the futurei know this thread is about c turbos, but what are some of the differences between the C and D turbos as far as seals and bearings? do the d's also use a bushing type bearing?... because i heard d's last longer than c's. thanks for your insight!
That is the next step. I just completed the rebuild last night. Will post a video when I get around to itHey, have you put it on a truck to test it out yet?
I used q-tips and rubbing alcoholI'm not sure if I missed it(I did search for it) what did you use to clean the fans with?
