Turn signals not working
Vondy
Trenton, Ohio
All my lights work, including black outs except turn signals. They come on when I turn on the 4 ways but don't flash. The green light on the switch comes on but does not flash when left or right signal is switched. They were working intermittently when I first got the truck about six months ago. Any ideas would be great. I'm planning on going to the Mid Ohio show the end of the month and figured I should get them working by then! Thanks to all.
Barrman
1,621
Giddings, Texas
Then check the flasher itself.
Pin “A” to a light bulb which is grounded
Pin”B” to a 24VDC source
Pin “C” to ground
When “B” is connected, the light should blink about 80 times.minute
Vondy
Trenton, Ohio
Got em working last night. Took the plug off the flasher unit, sprayed the bolts and ground wire with wd40, let it sit for a bit hooked back up. One step closer to going to the MV show next weekend!
