UGC-74 teletype
mm58
9
Tucson/Arizona
Just learned of the existence of a cool little RTTY machine, the UGC-74.
Looks to be a good compact size for MV installation and playing with ham radio RTTY.
Anybody have experience with one? Pros? Cons? Words of wisdom to a possible buyer?
Spec I saw says it needs both 28vdc and 115vac. Is this true, or can it operate solely on either?
Thanks for any help
Mike
m38inmaine
65
Maine USA
I had one working in my AN/GRC-142 shelter. It will use either stand alone voltage, I ran mine on 115v AC. You will also need a cable to the modem and radio. New ink ribbons can be tough to find, mine was a UGC74"B" model.
papakb
1,185
San Jose, Ca
At around 85 pounds they certainly aren't portable even if they do have handles! Don't buy an unlettered model, stay with a C model if you can, they have dot matrix heads in them instead of character drums. Lots of nice options for them, even a memory pack. Fairly straight forward to interface and use, just on the heavy side and I'm not sure if I've ever seen a shock mount for one. Maybe I'll dig mine out one of these days.
Kurt
KG6KMJ
eme411
pefferlaw ontario
Hi Guys, I'm working on a 142C , I have found NOS teleprinters with the paper and ribbon kits and NOS cables , do any of you have the sliding rails under your printers? I need to see what these look like and how they mount , there is also a version that mounts the printer solid into the racking,
