- 2,479
- 24
- 38
- Houston Texas
I took mike's advice and installed a glow plug relay. I mounted it right next to the batteries. And it works great! Every CUCV i get in the future will get this mod.
Finally! - someone knows what the true function of a relay is.... Doghead, you da man!It does not convert, it is a relay.(an electronically activated switch)
The starter relay is triggered by 12v, and it switches 24v(the key switch applies 12V to the relay coil, closing the contacts and the contacts are supplied with 24v and that in-turn goes to the starter solenoid).
If you convert your truck to 12V(all of it), you could leave the relay in ,or you could remove the relay completely and jumper the purple w/white stripe wire to the purple wire. It depends on how you want to(or are told to) do it.
SO that's what the Doghead relay modification is.It does not convert, it is a relay.(an electronically activated switch)
SO that's what the Doghead relay modification is.![]()
