V100 mods
135gmc
St Paul/MN
If that is how you make your living, congratulations! You have the skill and the equipment to turn what some folks would call a major project into fun.
If you like what you do, every day is good -- maybe some are a little better than others, but they are all good.
You're building a really great looking V100 - I've seen MIL contractor's prototypes that aren't as carefully done.
steve6x6x6
Winter Haven, florida
Don't forget inventory.
wgtactical
412
Carrollton, Georgia
Thank you, but this is not my primary source of income...and if it were I’d probably starve to death because it takes me too long to get things the way I want them :razz:
Very well put [FONT=&quot]:beer:
[/FONT]
jimk
47
Syracuse, New York
Stock is 20". It's the same as my M813 but the 5t has a horn button and the V uses a flat metal cover. I got one for the deuce (air-o-mat) on e-bay. It was a NOS piece. Cost was $45-buy-it-now maybe 5 months ago. The seller was Italylovers. I Think Virginia said she had 12 more. After I got it I found that I had a spare in black all along, so used old one and save the nos item, which btw is a very dark gloss OD. The one in your picture looks like the 22" that I took off the deuce. Spokes with a square profile and a much larger horn button area...Maybe a later style.
M813rc
3,819
Near Austin, Texas
My V came with a black wheel and an OD one, other than colour they are identical. I'll have to compare them side by side with the one in the M813, but they look similar.
I used the black one because that seems to be what is in most V pictures.
I have a deuce rubber horn button cover in mine just to fill the hole, but it doesn't look right (too domed). Jim, can you show what the proper metal cover looks like up close? I'd like to find the correct bit.
Cheers
Edit: The V wheels are similarly sized, but different style, than the M813. They measure out about the same, but short of pulling the 5-ton steering wheel off and test fitting, that's as far as I can go.
jimk
47
Syracuse, New York
I have a deuce rubber horn button cover in mine just to fill the hole, but it doesn't look right (too domed)...
I was mistaken, it does -not- have a metal cover. It uses mostly the same parts, without the wire, like your V and my big trucks. The cap (cover) is different. It is almost flat, thin, and rubber.
