Vacuum Reg Valve, need it?
HAWKMAN
N.E. P.A.
How much trouble will I get in if I eliminate the Vacuum Regulator Valve and hook directly to pump,I just need to move truck a short distance and VRV isn't allowing vacuum to the trans modulator....bites driving it in second gear. :x
SmokeyDod
Easley, SC
The vac or modulator don't have anything to do w/shifting from 1-2-3 just when and how hard it shifts. Sounds like you have a problem in the valve body of trans.
69dieselfreak
rimrock az
i just got my truck running yesterday so i went to take it for a test drive check the fluid and all
first test shifting irraticly but really hard when it did so checked my fluid it was over full and air ated :?: took it out again and had no shifting 2-3 it still 1 and reverse so what am i looking at doing thanks guys
flewbyu
Virginia Beach, VA
Bump to the top for you, I'm interested in this info as well...
Found new VRVs through Amazon.com. Brand new, ships in one day. $100 including 2 day shipping.
