- 10,350
- 94
- 48
- Meadows of Dan, Virginia
About 1-1/2 years ago I could by fresh restaurant fryer oil for less than $14.00/35 lb (4.6 gallons), now it's over $22.00!!!
Well, it would seem to depend on the food.Guess it's not so good to use a food for fuel....
Surprising that it is about the same as water. Figured it should have been higher.cranetruck said:Yes. 7.61 lb/gallon
I got thinking about this. Basically to extract or turn corn into alcohol don't you have to have what essentially would be one big bad a** still ?? Does'nt it take a fire under the still to do the job of making the alcohol ?? But then I got thinking, don't beer/whiskey brewers put corn mash into huge vats and let it do it's thing also ?? Either way, would'nt it be impractical to make ethanol because of the expense of using fuel to make it or to let it sit in a huge number of vats ??ARMYMAN30YearsPlus said:Corn is being used more and more for the production of ethanal I saw an OP-ED piece on the fact that more farmers are planting corn where they used to plant barley and now the price of beer will be going up as well. I don't think my deuce would run on beer so that doesnt bother me.
