voltage/amp meters on m1008
Hammy
STL, MO
I have two digital voltage and amp meters they can each handle up to 30 volts and one of them is rated for 100 amps and the other is 200 amps. They use a shunt to wire up.
I'd like to use one for each alternator or battery. So I'd use on to track the 12 volt system and the other 24 volt system. But I'm not sure how to wire these up with the 2 alt. System.
Here's a link to the type of meters I have.
http://www.amazon.com/gp/aw/d/B00GH...5_QL70&qid=1402611082&sr=8-77#ref=mp_s_a_1_77
Thanks for any help.
doghead
4 Star General /Moderator
1,187
NY
You have 2 12 volt alternators.
There is no 24 volt charging to monitor.
doghead
1,187
NY
Not if you want to monitor each battery and alternator separately(most accurately).
doghead
1,187
NY
Did they come with instructions?
To be quite honest, the dash lights will tell you if they are not charging and the volt meter has a hash mark that is easy to reference as well.
Why complicate this?
