Voltage Regulator on 60a Alternator
ParkStaff
zoozoo777
Thank you So much for the fast reply! The outside of the case on the link you sent me looks exactly the one I have purchased that is about 1 MM to large to fit into the alternator and has 4 male connectors on the inside as opposed to 3 male connectors on my original voltage regulator.
How can you identify this is the correct regulator without seeing the inside of it?
Thank you!
Smckerigan
14
Scottsbluff nebraska
I had to get the manufacturer’s name of the generator and talked with southern auto about which one I need and he sold me the correct one and it did have a extra spade terminal but just attach the correct number off the wire to the spade marked on the new one. Hope this helps.
papakb
1,186
San Jose, Ca
There were 2, 60 amp alternators used in the HMMWV.
The early one is model AMA5102UT. This one uses regulator AMA1004A, 4 pin type connectors on the regulator and no resistor.
The later (current) model is AMA5104UT. This one uses regulator AM2004AS, 3 blade style connectors on the regulator and a 50 ohm, 50 watt resistor on the casting. This is the only replaceable part on this assembly.
If you want to try replacing the resistor first I have them and can send you one if you PM me a mailing address.
