DanM7890
- 11
- 38
- Hickory, NC
Goes from the head to the pump
(And) You have an easy fix plus complete the 'mission' with that fault (rectified), the other (simple) option Stout or re-enforced rubber tubing, stout clips. (4 off.) good luck, keep us informed.just a get a simple compression union and splice the tube together to get you home.
That's a beautiful sunset there Dan. Try to look up from the task at hand every few minutes to enjoy where you are. I'm offering a prayer for a fellow LMTV owner. You'll make it through just fine.Trying to stay positive.
My truck had both the broken line and the cracked timing housing you pictured. If the bracket that supports the compressor becomes loose the housing becomes stressed and will crack. My guess is the line also cracked due to the compressor moving. At least this was the case for me. If you need the timing housing they can be sourced used. A new one is close to $1,000 from Cat. Unfortunately the camshaft needs pulled to replace the housing. If you were closer I would lend a hand, the job isn't hard but a lot of parts need to be removed.I believe I found the source. Looks like a cracked cover. May have to zoom in. It's a small leak.
thanks for the heads up. I'm heading into work trying to keep my mind clear knowing I have a lot of work ahead of me on the truck. I actually am from Dublin and went to elementary through high school there. I still make it back for an OSU game when I can. Thanks again.My truck had both the broken line and the cracked timing housing you pictured. If the bracket that supports the compressor becomes loose the housing becomes stressed and will crack. My guess is the line also cracked due to the compressor moving. At least this was the case for me. If you need the timing housing they can be sourced used. A new one is close to $1,000 from Cat. Unfortunately the camshaft needs pulled to replace the housing. If you were closer I would lend a hand, the job isn't hard but a lot of parts need to be removed.
Sounds like my history with VW Beetles, Karmann Ghias, and Triumph Spitfires!A senior female manager asked me how I figured out the trick with the bungee and I told her that growing up I usually drove $50-$75 vehicles. You had to know how to make field expedient repairs or you'd be sitting beside the road for a long time.
Only Beetle I had (one of my expensive models at $250) caught fire and burnt to the ground. I couldn't fix that oneSounds like my history with VW Beetles, Karmann Ghias, and Triumph Spitfires!
