waste oil/waste trans fluid mix for Deuce use
Manstein
Chaplain Emeritus
331
Cartersville Ga.
Does anyone have experience mixing waste oil or transmission fluid with diesel and using as fuel for multi-fuel engines? If so, what %'s are you finding acceptable?
rdixiemiller
Olive Branch Mississipi
I have run between 25 and 50% waste motor oil with no issues other than the smell at higher concentrations.
25% is a good place to start. I pump my oil from a drum with a hand operated fuel pump with a regular diesel fuel filter/separator on it.
ken
27
Houston Texas
I run used motor oil at different %'s. The price of diesel is the major factor. when the price goes up so does the amount of oil i use. Never more than 50%. Usally 25 to 30%.
I had problems with the primary fuel filter stopping up. But i bought a centrafuge and started slinging the soot out. You can also dump some gas in with the used oil to thin it a bit, if your worried. Be sure your FDC is hooked up and working!
1,163
What is "FDC"?
The fuel density compensator. Do a search for it in the deuce forum and you'll find lots of info.......
