Water leaking from head?
Colonel Smash
Cabot Arkansas
My Deuce leaks water from between the two heads. And I'm guessing it's either a blown head gasket or a cracked head. Has anyone ever had this problem??
By the way, I did not use the search option. But I know it's there! Thank you.
swbradley1
Modertator
1,939
Dayton, OH
Are you absolutely sure of where it is coming from? I ask only because I spent a lot of time tracking a leak down and it wasn't coming from where I first thought.
In my case it was those pesky hoses on the passenger side manifolds. First time it got cold in 2010 it started leaking and I waited until after winter to fix it. First time it got cold in 2011 it did the same thing in the same place. Turns out it was the clamps. :-(
