Water Separator Filter Removal
America
35
USA
Anyone have any tips or idea how to remove the filter from an MEP803a. It really is stuck on there.
The answer is just to turn it harder, Use a cheater bar and a strap wrench or similar. You might as well get a hole set of heavy duty strap wrench’s if you don’t have them. Don’t buy the ones at the big box stores they are too weak.
BobbyT
Benton, Arkansas
I just went out of my comfort zone of lots of filtration (and listening to @Guyfang about filters) on my 802a and just removed all the filters and replaced it with a single Racor water separating filter. I kept the 10 micron on it for the initial run after i went through everything, but have the 2 micron on it now. I moved the crank switch up to allow the new filter to mount in an easy to view/access spot. I just bent, cut and flared the original hard line and made all new rubber hoses from there on with Gates 1/4" hose and fuel injection clamps.
I think it should be plenty of filtration and now that its easy to see, drain or change, is a lot better than the original setup as far as user friendliness.
I'm all about making things simple and easy.
BobbyT
Benton, Arkansas
They are rated for 15 gph, so it should be ok. I think the pump is rated at 25gph free flow. Seems to work good so far and has plenty of return flow to the tank. But i will keep an eye on it and can switch to the R20 series that's rated for 30gph if needed.
