- 3,923
- 76
- 48
- Comfort, Texas
Got plenty of shops who will do it but the price is steep. I will keep looking. Panshark, I will be trying the rust removal tip this weekend. Let you know how it turns out.
OK..I know you want to do this right...we all do.Well, as it turns out, removing the tank was not too bad. Unfortunately when I dropped the tank, I heard a loud knocking inside. I got the sender plate off after all the screws sheared off, to find that the tank baffle is loose. I called John at Midwest and he said he could have it repaired and sealed but we are looking at north of $400. Others have quoted $500 to $600. Needless to say, I am crushed.
Going to try my local welding shop to see if they can repair the tank and I can clean and seal it with the with the KBS coating kit like I did my deuce. If not, I may be converting this Sum Bitch to PROPANE.
Sorry, no photos today. You cannot take pictures of gloom and doom.![]()
Fine then!!!Thanks PB. I found the Carter air horn, mounting sleeve and original air cleaner from John and Midwest. Those should be here next week.![]()
