I have a Wrangler M/T with a slow leak. I have shot soapy solution all over this thing and can't seem to find any leaks. I may need to remove the wheel and lay it horizontally to check for leaks again.
Is it common for the wheel O-rings to spring a leak? It doesn't seem like a big deal to replace the O-ring as long as I'm using the same tire and run-flat. Am I missing anything?
