I'll try to keep this short....
Bobbed Deuce on 395 XML's. Had it for 3-4 years with no problems. Plenty of 55 mph cruises, everything fine...Never really off-roaded the truck. Never in mud or water...always the same tire pressure...
I got a call to help a guy out that was stuck. To get to the guy I had to get on some train tracks, drive down them, then off to get to him...Then the same to get back out....Large tires with no power steering and going over the tracks means I was fighting the steering bad...I dont recall if I had the transfer case locked in, but probably...
Once I get back off the tracks I can tell something is seriously wrong with the steering. It's very hard to turn left, and feels like it will skip, then whip the **** out of the steering wheel the opposite direction...On pavement, I really couldn't go over 7-10 MPH without losing control....Almost feels like the transfer case is still locked in while turning, but that wouldn't explain the issue going straight...? Its an air case...
Nothing looks bent. Alignment measures to be about 1/8" toed in. So i figure I screwed something in the steering box up...I get a new box and decided to split it before I put in to make it easier. After looking at the internals of the new box, I figured I surely chipped the worm gear or broke the nub off that rides on the gear...
I get the box open in the truck, and it appears fine. Nothing broke chipped or bent...Pitman arm isn't stripped...So i've got new bushings and a seal for it as it was leaking a little...I didn't try any box adjustment before I split it. Surely there couldn't have been enough play for it to jump over the worm gear?
Now I am at a standstill here. I still have the box split in the truck...
I did notice with the front jacked up off the ground, the front tires aren't spinning like an open differential, but they arent spinning like they are quite locked either...They spin the same direction, then slip a little, then spin more...The rear act like a true open in that they spin opposite directions...Maybe I snapped something in the front axle???
The only thing I can find that probably needs replacing is there is a bit of play in the driver side wheel bearing. I honestly cant imagine that causing this problem though....
Any suggestions or ideas? Concentrate on the front axle?
to what Rustystud and Welldigger said.
