- 2,102
- 28
- 38
- Delta Junction, Alaska
View attachment 522081View attachment 522082View attachment 522083View attachment 522084View attachment 522085View attachment 522086Along about the middle of July, I got things together to go up to Central, where I've had a cabin for 40 some years. Its been a dozen years since I have been there, and thought the grass might need mowing by now. As it was, I found 5" trees in the driveway. Its pretty remote, so I had to take everything I might need. I knew, the house was literally falling in, the wall tent is traditional, and a weeks stay warranted a fridgerator, small heater & plenty of bug dope. The rest was pretty elementary, which is my style. The mobility box was fantastic, for keeping small stuff, stuff dry & clean. It rain alot & there was dust & mud. The blue barrel is potable water. The generator is a '49 single cylinder diesel, 3000KW Onan, which I built the cage for w/fuel, battery, etc., making it self contained. Of course, I had the forks, which made the palleted stuff, easy.![DSCN0009.jpg DSCN0009.jpg](https://www.steelsoldiers.com/data/attachments/356/356399-f551ee3f986f2e9a11ffdcb15a8e6694.jpg)
The Road part: Its about 250 miles from home. The last 75 is on gravel. From Fairbanks, there are three sizable passes to pull (the 1st picture is Eagle Summit), where one's gear shifting skills will prevail. I had to learn about low range & using it. Of course, once you get to the top, the down side is just as important, and its best to keep things under control as a Deuce is capable of Mach 2 there. The truck has a re-done brake system and the service brakes work well, with the trailer doing its share of the work. The trailer is full air with spring pots, being a recent rebuild. I'm more impressed with the trailer's brakes, then I am with the trucks, but there is no way to control them when parked, on a Deuce. When I would stop to stretch, I'm just not real confident with a mechanical drive line brake, holding the whole outfit, but would like to see those spring pots on the trailer, holding too. A Tractor Protection Valve is in order next. Pulling the grades, I don't like stopping till I get to the top. On the 1st grade, the temp gauge showed I was getting hot. There is a brand new radiator, and knowing Wreckerman's opinion of the accuracy military fuel gauges, I didn't want to believe the temp gauge either. There was plenty of heat, and at the next chance, I dropped the side panels, which did wonders, and that relieved much of it. The Outfit did well & I made reasonable time & speed for the conditions. Of course I was heavy, as some might note, but in the Old Days, on the old road, I pull the same kind of loads with a 211 gasser (that was when I didn't know any better), thus the multi-fuel with a turbo is a real step up. Other little things were some loose oil blowing around. There was never a slobber tube & that did much to remedy that. The compressor belt started squealing when I would start the engine, but regardless of tightening it, I had to change it out (yes, I have the wrenches).
The best part of the Trip, were the looks I got on the road! A lot of double takes!![DSCN0016.jpg DSCN0016.jpg](https://www.steelsoldiers.com/data/attachments/356/356394-42004ae357f19922acde2425fa678870.jpg)
![DSCN0025.jpg DSCN0025.jpg](https://www.steelsoldiers.com/data/attachments/356/356395-08d6fc2d00279778ca9b9691199db31a.jpg)
![DSCN0002.jpg DSCN0002.jpg](https://www.steelsoldiers.com/data/attachments/356/356396-975ebbe5e9c5411c87cc50f67e7ab159.jpg)
![DSCN0007.jpg DSCN0007.jpg](https://www.steelsoldiers.com/data/attachments/356/356397-a95c23545d799f01595dd67b21165972.jpg)
![DSCN0006.jpg DSCN0006.jpg](https://www.steelsoldiers.com/data/attachments/356/356398-5fd4cf289d30ae68864c45e994298bab.jpg)
