- 34,010
- 1,827
- 113
- GA Mountains
That is correct! Cutting them down reduces the amount of oil that can drain back to the very minimum. As long as filters are mounted upside down, a certain amount of oil will drain back. There are bad things that come with every mod though. With this one, the oil doesn't go back in the pan as the military designed it. The design was to keep the oil warm via heater, in sub zero environments. Here is the bad news. The bases used in the ODI kit are no longer being produced. Until another base can be sourced, the kits can't be completed.I'm confused. ODiron's kit uses a new remote filter mount, but reuses the stock (cut-down) filter housings? Is that right?
