iluvbudwsr
- 1
- 0
- South Alabama
"when it rains it pours"! I have been reading thread after thread using the search feature and I'd like to get a few ideas before I go through more money! I've been spending so much money on this thing lately im about to give up. I've had a problem with hard starts ever since I bought it. The fellow I bought it from said it had a pin hole leak in one of the fuel return lines. I replaced all these among several other fuel lines. they looked alittle dry just from being an 84 model but I did'nt see any leaks or any of the sort. When I cold start it, it fires up and then hesitates and dies.on the second try it hesitates like crazy but it will finally fire. I can drive two miles and shut it off and run into get a soda and come back out and it fires right up. If I drive it for more than 30-45 minutes and leave it sit and try to start it it wont fire. I've checked the glow plugs and everything is fine. Im starting to get alittle iiritated so I took it to my local mechanic and he did'nt even want to fool with it so I called a mechanic friend of mine and he said with 70,000 miles on it, it could be time for a new fuel pump. I priced one at autozone and the computer said they're only 26$. Does this sound like like a fuel pump problem? I've checked and replaced most of the fuel lines. Any help here would be much appriciated guys!
