What are the two items on the gauge cluster at 10 and 2 o'clock from speedometer?
bfdvollie
Belleville,MI
What are the two items on the gauge cluster at 10 and 2 o'clock from speedometer? They have a singular electrical connection, but I see no function. The unit we have has these painted.
nattieleather
135
Cleveland, OH
I believe you are refering to the dash lights. There should be a light bulb in each of them that will back light the gauges when you have the lights turned on. The operator manual will show you how to turn them on.
TedG
MI USA
Yes. The dark plastic is the lense. They can be red, green or blue plastic. Also, yours have been melted from the bulbs being to high of wattage. This was a common problem with the early series hmmwv. I believe a MWO was assigned to replace them with a lower wattage bulb. The bulb is inside the plastic and you unscrew the plastic housing from the metal base. However, when melted, it will break so it is best to obtain an new assembly. Hmmwv dash light asssemblies (plastic portion) are a different length than other M-series dash lights, so finding a replacement might take several attempts. Measure your plastic lense so you know what length you need from supplier.
While the dash is out, clean the ground on fire wall behind heater switch and use star washers on both sides of bolt.
bfdvollie
Belleville,MI
Ok I got it unscrewed and it's a very dark green. I plan to do a bench test and see what the bulb is doing. I'm assuming this is a positive lead at the bottom with a chassis ground.
TedG
MI USA
ITEM NSN PN Description QTY
1 PAOZZ 6210012084790 19207 12338465 LIGHT,INDICATOR..................... 2
2 PAOZZ 6240007658443 24455 1864 LAMP,INCANDESCENT CLEAR............ 2
2 PAOZZ 5980014387452 19207 12460228 SEMICNDCTR DEVIC PART OF KIT P/N57K3238 2
3 PAOZZ 5305012111439 7X677 9414224 SCREW,TAPPING....................... 2
4 PAOZZ 6220012730500 19207 12356703-3 LIGHT,INDICATOR..................... 1
5 PAOZZ 5330012115856 19207 12338462 GASKET.............................. 1
6 PFOZZ 2510012488875 19207 12338467 PANEL,VEHICULAR OPE................. 1
7 PAOZZ 5305009846191 96906 MS35206-243 SCREW,MACHINE #8-32 X 3/8.......... 4
8 PFOZZ 2510013035769 34623 5585111 PANEL,VEHICULAR OPE................. 1
9 PAOZZ 6685011809037 09527 GG0490 INDICATOR,TEMPERATU................. 1
10 PAOZZ 6625011806542 34623 5568666 METER,ARBITRARY SCA................. 1
11 PAOZZ 6620011811757 09527 GG0552 GAGE,PRESSURE,DIAL.................. 1
12 PAOZZ 6680012980498 34623 5568667 INDICATOR,LIQUID QU................. 1
13 PAOZZ 6210012117024 19207 12339203 LENS,LIGHT.......................... 2
13 PAOZZ 6220014294596 19207 12339203 1 LENS,LIGHT INSTRUMENTCLUSTER,CLEAR 2
PART OF KIT P/N 57K3238...UOC:BVY,B15,B20,B24,B25,C17,NNN 1
4 PAOZZ 5330002976329 19207 7358626 PACKING,PREFORMED................... 2
