- 18,629
- 6,299
- 113
Sweet -
Ref pic 5 above.... is that the "bunk" in the upper right side or is it a shelf?
Congrats on the score.
Yes, and yes. I think it is the bunk, but I might use it as a shelf.is that the "bunk" in the upper right side or is it a shelf?
If you ever do put eyebolts through a tree, make sure it is in winter after a freeze or two when you are certain the sap isn't flowing. Otherwise, it won't last but a year. January or Febuary is about the only time you can pull that off.I have a S-788 shelter that might be appropriate for that. It is 608lbs empty and made from aluminum honeycomb material. I thought about hanging it from aircraft cables attached to 4 trees by the 4 hooks at the top, and attaching eyebolts all the way through the trees. I think the trees should support the weight, but I wouldn't want to be in there in a high wind. Has anyone ever actually pulled off something like this?
