- 1,191
- 453
- 83
- Lockport N.Y.
I am looking for the pins for the west coat mirror setup , I picked up some shoulder bolts from McMaster-Carr , should work ok , slightly oversize , which is good for a worn hinge.
I drilled the holes out to 5/16 and used 1/4" stainless bolts, this worked well.I am looking for the pins for the west coat mirror setup , I picked up some shoulder bolts from McMaster-Carr , should work ok , slightly oversize , which is good for a worn hinge.
Been busy all week....
1. Sprayed u-pol raptor tintable bed liner on the inside of the cab, and roof.
So. How do you like this bed liner so far? Did it spray well? Any pics?
I haven't figured out how to add photos, but if you PM me with an email address I'll send you photos.Been busy all week....
sprayed really well, it was harder trying to figure out the mixture ratio as the instruction were wrong, and it wasn't until I found instruction on the net that I got it right. I got the tint from Napa because Carquest was unable to do it because the "computer" wouldn't read the sample. Go Napa, plus it was cheaper. Prep is important, I set the pressure at 40 lbs and got the texture I wanted. I am very happy with the results.
Napa was able to match the Behr OD paint. If you buy the tintable bedliner you need to buy tint from napa. Or just go black and not worry bout it.Napa was able to match the bed liner? Cool.
WHOA ! ! !Friday I spent getting the M109 it's antique mil-veh registration. Well, almost. Filing a Texas SR-2 requires mailing the darned thing to Austin with a self-addressed, stamped envelope in the hope they'll get right on it and send the copy back. Until then, the registrar won't do squat. Naturally, Saturday I found the original SR-2 from the previous registration. But, what the heck…I'm nearly through with that. By the way, if any of you expect to get past the Austin Texas Dept. of Public Safety menu and talk to a real, live person….forget it. At the end of the menu it tells you to dial zero if you want to talk to a customer service representative. If you dial zero, the menu says "good bye" and hangs up on you. That's a dirty trick if you ask me.
Saturday, I finally got all the honey-do's out of the way. Time to pull the M109 out of it's parking space after replacing an in-tank fuel pump last week.
Pulled slowly forward onto the concrete driveway and….no brake pedal! (Note to self - Check brakes BEFORE moving next time!) Master cylinder reservoir was e-m-p-t-y. I admit I haven't checked that since I bought the truck. My bad. Took a ride on the creeper and inspected the belly of the truck and there was NO evidence of leakage. Bizarre. Was it nearly empty when I bought the truck from GL? You might argue I should have checked way back when but I was spending a lot of time in Afghanistan back then. I was busy, OK?
Anyway, I refilled the reservoir with DOT 5 and bled it. I had some resistance now, but still, a fairly lousy pedal. I gently pumped the brakes, observing what I expected to see…bubbles coming up from the bottom of the reservoir. Did that till the bubbles stopped coming and (Success!!) ...now I have a nice firm pedal.
GL mangled the tail-light brackets and the right rear mudflap, along with the floor channel the mudflap hangs from. I had planned to replace the mudflap and even have a brand new piece for that but I was feeling so good about the brakes I took the mudflap off and took a hammer to it, which is no small task given the thickness of the metal. Grandpa was a body man wielding a hammer and dolly, way back when cars were made of heavy steel. I must have inherited some of that because having no formal training, I've always been good at straightening mangled metal with a hammer. I took a thoroughly FUBAR mudflap and turned it back into a nice, straight piece.
Tomorrow, I hope to straighten those tail-light brackets and repair the floor channel!
