tobyS
840
IN
Nice truck! A little fresh Behr and it will look new. I bought several trucks when they were more plentiful for parts, but never could do it to a running truck (after I got them running).
Sparkyz911
61
33
Central IL USA
It has been well taken care of for sure. Runs like a beast. It's had the spin on filter adapters already done, 11 20 GY 177/188s, 2inch hitch receiver and a bed crane put in. My only plans are reupholster the seats, bedliner the inside cab tub, install reverse lights w/switch mod, add the stencils (TP, fuel level, drain tank, check batts, etc), and an electric winch. Mechanically it needs nothing, well, except the normal maintenance stuff all deuces need.
Another Ahab
4,982
Alexandria, VA
Man, you hit the jackpot with that find. :beer:
Elijah95
Certified Rookie
1,247
1,228
Georgia
Pics as requested. Purchased this from another SS member. While doing my research I found that another SS member was the 2nd owner after DRMO released it. (The first photo credit goes to him). Still trying to track down the rest of the history. I initially planned on buying a beater and crew cab it (no bob) but this thing is in such great shape I'm gonna leave it as is.
View attachment 667857View attachment 667856
Beautiful truck!
nchittendon
La Crosse, Wisconsin
Didn't realize how dirty she was until I hit it with the pressure washer.
So, she got a bath. It was over due. Had to get all that road salt off.
Once daylight hit, I noticed some rust forming where this bracket touches the pipe. I pulled the bracket, sanded, and slobbered a lot of paint on there. Should hold for a while.
Then started fitment of my hood blanket.
sigo
Lieutenant Colonel
445
Leavenworth, KS
Looks good! Taking care of little bits of rust as they form is excellent PM. Wish I had time to do that kind of detail work. Great work preserving that old iron!
deuce2
carson, nv
EXCELLENT! She looks wonderful. Ive only had one for about three months. Minor issues here nd there, but never the less, still fun.
tobyS
840
IN
Winter fronts are nothing new, but don't believe I ever ran across a hood blanket.
Was that all part of one kit, or was the blanket a little harder to find?
I think I would like the insulation on the outside (removable) better than inside, where it seems to get water absorbed, then cause a rust issue.
CHIEFSONN
I completed my cleaning out most of the bribe from in my fuel tank ,sanded and primed tank, rebuilt in tank pump,installed a pressure gauge in the discharge line, set it to the correct height at 14" measured from top to bottom,new hose and gasket, installed the correct fuse from 10 to 1 amp. installed fuel float .connected all lines,
I bought and installed 850 CCA batteries I purchased from coastco, $93.00 a piece the brand is interstate group 65, coverage is good for 42 month. ITEM # 850259 automotive fit code 4 with free replacement. g with installing them in the plastic stock battery holder that replaced the steel one that was there when I bought the deuce.
Turned accessories/ignition switch on ,in tank fuel pump putting out 10+ psi bled air from secondary and final filters. turned over motor with stop pulled out, pushed in stop and started motor , bled air from injectors.
Question when running my deuce with the new batteries the power gauge on the dash fluctuate from the green to just touching the yellow. battery voltage does not hold a steady 28vdc at 1200 rpms that also fluctuates from 28.5 to 27.? how do I stop this. also got my low air pressure buzzer to work,did not work when I bought her but I do need to replace the # 85 wire where do I get one. thanks
Aussie Bloke
415
Lost, out bush in OZ
G'day everyone,....
In an hour I'll collect my deuce and with luck by lunch time I'll have replaced my lower radiator hose and have the cooling system flushed and replaced with all new coolant.
Then tomorrow we will go to our first Car-Show.
Aussie.
maa45069
71
cincinnati/OH
You can play with the screw on the alternator itself to increase or decrease your voltage. My gauges jump around no matter what I do... ya Costco always has awesome deals on everything
Sent from my SM-G935T using Tapatalk
Another Ahab
4,982
Alexandria, VA
G'day everyone,....
Aussie.
You got to please get us some pics, Aussie Bloke.
Aussie Bloke
415
G'day everyone,...
Ok,.... I am back after going to collect the Deuce,....
Wanna know what the saddest sound to hear is,...?
Its when you press the start button and all you get in return is: Click!
One of the batterys has melted its post.
I can lift the post up a whole inch it is that loose.
The lead has mostly melted off and just left the copper looking post behind, burned.
I still get 12.85V from both batts.
I will charge up the good batt over night and get a new batt to replace the one with the melted terminal Monday.
I have been meaning to replace the batt terminal clamps, I have them already but never got around to actually changing them over to the new brass ones I have.
And whats more I think I know when this happened, it was the Sunday when the radiator hose got the pinhole in it.
That morning when I went to start it there was a POP! and arcing sound but it started ok as normal, I had my mind on the coolant leak at that time,....
I have only gotten the Deuce out once since then and it started just fine last time.
Did I ever mention that the Universe is conspiring against me!??
:-x
Aussie.
maa45069
71
cincinnati/OH
G'day everyone,...
:-x
Aussie.
It is always sad to hear bad things about our vehicles. I'm sorry to hear but on the bright side this is a very small problem. Be happy it's an easy fix. glad you figured it out
Aussie Bloke
415
G'day everyone,.....
Agreed, It is thankfully a small problem but it has ruined what was going to be a great weekend.
After the last weekends with hard work for others I needed to have some fun for me.
sigh,...
But once I got it done!,...
Aussie.
