Crazyguyla
- 124
- 43
- Altus, OK
I dreamed about my Deuce today. Still trying to get it in the same state I'm in.
Is that the "dream" state, or do you mean Florida?!I dreamed about my Deuce today. Still trying to get it in the same state I'm in.
I know the feeling. It's hard to have such an awesome machine parked at a distance.I dreamed about my Deuce today. Still trying to get it in the same state I'm in.
So why would you need to remove your shackles? Neat what you did, but I can't figure out why.I forgot to post about last month when I converted my rear shackles to the captured "safety-pin" style like the front.
I wanted the rear shackles to be as easy to take on/off as the front were and have a "captured" retaining clip. I previously had had the rear shackle pins sand blasted, so then I welded to the top of the heads an 'S' hook and crimped on a short chain, another 'S' hook and a the large "safety pin" style retaining clip. It is the exact same style of retaining clip used on the front shackles.
Moving to level 2 in the LED dash lighting experiment, going from cool white to red and green also. I started a thread for it here:
https://www.steelsoldiers.com/showthread.php?170155-LED-dash-and-other-uses
I haven't, but further back in the thread there was another member Gimpy referenced that went through the discovery process for replacing the bulbs with LED's, which required a longer lens. I liked how 18operator's lights looked, are indirect so I'm using the light strips... which I discovered are rather cheap in white (and more expensive in red and green).Erik's Military and industrial surplus has various Dash Indicator Lenses ranging from the standard red to blue, amber, clear and green. Has anyone tried just changing out their lens? I would assume the clear lens would give a good result.
To put a strap on them, and use them...maybe?So why would you need to remove your shackles? Neat what you did, but I can't figure out why.
Do you have fuse or a circuit breaker? I'm thinking there should be some DIN rail stuff, but only now starting to look.Dis some more on the 12v system today. Installed a master switch for the 12v system. I will eventually change it out to a military switch. Hooked up power to the tank drain heaters, installed a power outlet/USB, and installed interior lights.
View attachment 692578View attachment 692579View attachment 692580View attachment 692581View attachment 692582
When I took the PTO cover plate off you can see a large gear in there. Is that what the Chelsea PTO mates up to? Stupid question, but some AT 545's are missing the PTO gear in there? I don't know how common it is.Hank, does your AT 545 have the gear for a PTO?
Here is one on my 1545.
