tobyS
840
IN
Im a strong paratrooper, but I thought it best to use my engine crane to lower the bumber.
I also found most of the new fasteners I will need, all grade 8. i ordered the lock washers too.
And heres a picture of my "power tool", its an oldie, and I think it was used to fix WW1 tanks !
I looked at your first picture and thought that the chain would un-wind but the third picture shows you changed it.
Keep up the good work. Don't drop the winch on your toe.
FloridaAKM
395
Gainesville, Florida
The 1985 Deuce I got from GP last September now is sporting troop seats & a complete cover set of bows, staves & the camo cover from the Bellview show a couple of weeks ago. The bows were a bit rough mismatched set, but some paint work will fix that. The staves were all fiberglass in great shape, & it was too dark to critique the cover as it got dark as I was trying to put it on. Pictures tomorrow weather permitting.
10/28/2018: No pictures due to the NOS cover I got as a Deuce cover is a NOS 5 ton cover. ;-(. Since it is a show picked up item, there is no returning it.
Anybody know how to make a 5 ton cover fit a Deuce truck?
SETOYOTA
451
georgia
Im afraid I made a mistake, it is a M108. Its a hydaulic boom mounted on a deuce frame.
I have been rebuilding one for a while now. A hard to find truck. Most all originally were air force trucks. I have thread here on SS with the build. They have a double frame , made a little different than a M35. All are gas trucks. I have converted mine to a multi-fuel
Mrmag1
Head of Stuff N' Things
14
Hereford Arizona
Today thanks to fuzzytoaster I mounted new seatbelts ment for a 5 ton. They fit great and make it so I have three belts in the cab.
Note: you may not know who put in the original seatbelts in your truck.... So a impact wrench is needed sometimes...
Fatalid
11
Mesa, AZ
Spent the weekend flushing the coolant and replacing all the coolant hoses (some of which looked like they were VERY old), oil/filter change, and replaced both headlights.
Next up: go through entire electrical system... I have some guages that aren't working properly, the horn doesn't work, etc. Etc.
Sent from my Moto Z (2) using Tapatalk
whatadeuce
Loxahatchee, Florida
I found my M35 with the air compressor belt broke, as if the compressor was stuck. replaced the belt and found the air pressure going to high, So I ordered a new and adjustable regulator. Vendor said he never saw one lick this!I may also install a test guage for it
rustystud
3,380
Woodinville, Washington
Wow that is a weird one ! I've never seen one like that before either.
Menaces Nemesis
"Little Black Truck" Conservator
262
Denver, Colorado
Fixed my leaking speedo cable/transfer case seal, with the help of Gringeltaube's post here; https://www.steelsoldiers.com/showt...-cable-leaking&p=354570&viewfull=1#post354570, or it can be found by doing a search for "8x14x5 Oil seal".
Found the needed seal (2 ea. for $8 w/free shipping) here; https://www.ebay.com/itm/2-Pack-Gen...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
First pic shows the speedo adapter and wet cable. 2nd pic shows that the bad seal allowed gear oil to leak into the adapter drive. 3rd pic shows the sleeve where the speedo adapter was mounted, and where the seal is housed on the transfer case (the little black ring on the end of the sleeve was the old seal, it was loose in the sleeve and about to fall out. New seal was tight, and had to be pressed in). 4th pic shows how HUGE the seal is (old seal on left, new seal on right),
IMG_20181103_125159942.jpgIMG_20181103_125800172_HDR.jpgIMG_20181103_125922945.jpgIMG_20181103_153214379.jpg
And I replaced my old injection pump oil lines. The one from the block to the pump was starting to leak a bit.
Tubes n' Hoses of Loveland CO. made me a new set of IP oil hoses for $19.58 total. Old vs. new hoses, and a view from underneath, of the new hoses installed;
Fatalid
11
Mesa, AZ
Replaced the manifold coolant hoses, and the rubber hose connectors going to the oil cooler.
The manifold hoses turned out to be much more of a chore than I expected... Mainly because I didn't realize I would have to disconnect the coolant manifolds and make all new gaskets. Blah.IMG_20181103_150201818.jpg
