Another Ahab
- 4,966
- 113
- Alexandria, VA
Wishing that she gets that Golden Ticket!Please say a Prayer that my X gets her raise. If not I have to help her move from Louisiana to Jacksonville Fl
Love the Moon Pie sign (in the trailer)!The storage 30 footer is getting is share of the goodies.
James, If it happens to be, shout out and maybe we can do lunch while you are passing through the big easy.Please say a Prayer that my X gets her raise. If not I have to help her move from Louisiana to Jacksonville Fl. Spent two hours unloading the small cargo trailer if I have to help. The storage 30 footer is getting is share of the goodies.
Also loading up the 373 for the Denton show.
The power of prayer must be working so thanks if you said one she got the raise plus more.Wishing that she gets that Golden Ticket!
.Post Findlay '21 & M870A1:-
Must have measured all 60+ on site, found the only one that was 1 1/4" (&1") with hex hole... Fortunately I have a load of crow bars kicking around - one was 3/4" hex so it got decapitated. (Good-older ones are octagonal)
Got a pair of the 400mm deliniator plates from mwmules...
Picked up the last needed Crosby shackle (of 4) but that bolt is wrong - large bar of steel already in lathe, will turn down then thread at 5.5tpi. [Factory green one on left]
Other work done recently:
Spare tyre retainer...
Middle axle; wheels/hubs cleaned, new tyres, flaps, tubes, bearings and seals.
One bent cross member being straightened, will 'shrink' the stretched flange at some point ~ before paint and floor!
Looks great, zebedee!Other work done recently:
HA!!! Yes, UK ex-pat, been here since Aug 95.Wondering where you grew up, where you're from? Do you have a UK background?
How were you able to decide which aftermarket part number was the correct one to use? I've tried searching by p/n from the TM without success.Installed new monroe shocks to my M101A1 today. The old ones were just a little bit wasted. View attachment 835043View attachment 835044View attachment 835045View attachment 835046View attachment 835047View attachment 835048
I did the same - no results, no success. A good friend of mine changed the shocks on his trailer and they fitted perfectly. So I just did the copy and paste thing. Tell me if you need the correct part number.How were you able to decide which aftermarket part number was the correct one to use? I've tried searching by p/n from the TM without success.
Sent from my SM-G970U using Tapatalk
Pretty please with a cherry on top!I did the same - no results, no success. A good friend of mine changed the shocks on his trailer and they fitted perfectly. So I just did the copy and paste thing. Tell me if you need the correct part number.
